tvox tour
Posted: 12/3/2008 7:59:01 PM
teslatheremin
I would bet that the TVox has a vacuum tube in the circuit somewhere in the audio path.
It has the 'rough raw pinching' in the bumps of the sine-wave that change with pitch and volume.
And, it seems to possess absolute linearity.
Who wouldn't want to own and play one?
Good Luck!
teslatheremin
Posted: 12/4/2008 10:40:20 AM
Next bad news: Someone (in Switzerland) told me that someone (in Germany) would own one working and two defective tvox. I contacted this "someone" in Germany some days ago and got the answer today that this was a misinformation...
*weeping*
Still no Hanukkah gift that I could make to myself...
Posted: 12/4/2008 4:29:30 PM
"Any other theremin with a smooth timbre like this will also be welcome!"
Thierry - Having seen Lydia play, I bet she could make the Gakken an object of desire!..
You have an etherwave with 6 playable octaves.. You are unhappy witrh the tone - but (I presume) not unhappy with its playability.. You are thinking of possibly designing / building your own Theremin to get improved tone..
This MAY be a simpler solution - "Understanding, customising...your EW Theremin" gives details of a pitch to voltage converter - It is not the most elegant design, but it works.. One can also tap the volume voltage (buffer it with simple opamp voltage follower).. and one can take the raw audio (pre VCA) and 'mis-shape' this quite easily to get higher harmonic content...
Take the audio into a good VCF, have potentiometers to mix desired portions of the Pitch and Volume CV, and feed this to the CV of the VCF..
With the above you can get the tone as mellow or rough as you want, and get tone (Harmonic) variation as a function of pitch and/or volume as desired..
If one has a multi-mode VCF one can also select bandpass instead of lowpass filtering, and even get the filter to oscillate producing pure sine.
I am almost absolutely sure that the Tvox uses a technique like this - I think there is a 24db/octave Lowpass VCF into which the audio is fed, and that both pitch and volume voltages are mixed to give a filter cut-off which tracks changes to signals from these antenna. It is also possible that Q is voltage controlled in a similar manner.
It is just a shame we dont live closer - I would love to strap some modules into your EW and see if we could get the sound you want..
Or perhaps I should buy an EW and build a module to do this.. AAaarghhh! - So many options, so little time and money!!!
Posted: 12/4/2008 4:59:30 PM
[i]Having seen Lydia play, I bet she could make the Gakken an object of desire![/i]
Hmm...
Gakken Theremin Mini v. tVox Tour - the fight is on...
http://otonanokagaku.net/feature/vol10/mov01.html?file=flv/mov01.flv
Posted: 12/4/2008 9:46:18 PM
"Gakken Theremin Mini v. tVox Tour - the fight is on..."
Astounding! Gordon, how do you find these? Have you watched every Theremin recording ever made, or do you have exceptional skill with a search engine .. (or both)..
I was making a flippant throw-away remark - I never dreamed that Lydia had played a Gakken.. And yes, the Tvox certainly wins ;) .. BUT, Lydia did make the Gakken sound quite acceptable .. must admit, every time I see Lydia playing, my heart skips beats..
Posted: 12/5/2008 5:47:13 AM
I remembered that one from when I was researching prior to buying a Gakken.
Posted: 12/5/2008 7:10:55 AM
Thereminstrel
Gordon>>
Thanks for the video link; I REALLY enjoyed seeing LK playing the Gakken mini. I hadn't come across that video before ... probably because it's not hosted by Youtube, (I wish it was, I'd be adding it to my Lydia Kavina Playlist!)
This also reminds me that my Gak is still in umpteen bits waiting to be built!
Posted: 12/25/2013 11:26:00 AM
BJG
"I've been watching things for at least the last six years, and I've...NEVER...seen a Tvox Tour theremin for sale in any condition."
Since reading this remark a few years back, I've also kept an eye out for a Tvox out of curiosity, but never seen one, until it finally turned up in a random eBay search the other day. I see it's been featured on the front page, but I didn't notice a mention on the forum, so, congratulations to whoever nabbed the first of these beauties, and good luck to those bidding on the second.
http://www.ebay.co.uk/itm/tVOX-Tour-theremin-in-a-bag-obsolete-manufacturers-stock-/161178164949?pt=LH_DefaultDomain_3&hash=item2586f79ed5
Posted: 12/25/2013 7:24:37 PM
Wow, the first one sold for £2,150 (x1.64=$3526) the second is up to £2,150 with three days left on the auction.
Very interesting seeing the controls and I/O.  Does anyone know what that button or adjustment shaft below the "shape" knob does?
Interesting also that the volume response has two modes and no panel knob.  What type of connector is used for the antennae?
Posted: 12/25/2013 7:41:40 PM
The small switch below the the shape knob allows to select one of two basic timbres (more symmetrical waveform/less symmetrical waveform), whose brightness is then controlled with the shape knob.
The volume response has not two modes, besides of a muting switch. The volume tuning is done by holding your hand above the volume antenna at a height where you want to have max volume and pressing a push-button to trigger the tuning process. The instrument then adjusts itself with the help of an internal electronic potentiometer.
There are no "connectors" for the antennae, but simple fixations. A threaded one which allows to screw the pitch antenna in, and a clamp one which keeps the volume antenna in place just by pushing it in.
