Etherwave antennae
Posted: 1/1/2006 4:40:31 PM
Travis
by how much did you increase the capacitors? and also which capacitors are these?
thank you very much for all of the help. i am working on my theremin for my school synthesis project, and im going to try and write a peice on it.
-Travis
Posted: 1/3/2006 4:06:27 AM
alf
Yeah, it would be interesting to know how many loops you did with the magnet wire for the "linearize coil"...
Thanks a lot!
Posted: 1/3/2006 10:39:52 AM
alf
I think the capacitors he means are C8 and C10
Posted: 1/3/2006 11:26:44 AM
alf
Sorry, I meant C6 and C10
Posted: 1/3/2006 9:08:46 PM
Travis
how much did you increase the values of c6 and c10?
thanks for your help.
-Travis
Posted: 1/4/2006 12:32:33 PM
alf
I'll try myself when I have time, but it would be interesting to know what values you tried.
Also, did you remove the lower octave or the higher?
About the other issue:
I'm still thinking about the coil, that red one I can see in your photos... So you wound it "by hand"? I never did coils work, so I don't know exactly how to do it.
Another solution would be to buy several coils and put them in paralel (like Etherwave does), experimenting till you see the linearity is correct...
Posted: 1/4/2006 12:57:09 PM
Etherspiel
I'm sorry that I can't remember the capacitors at the moment - they are the ones that are part of the LC circuit. I will have to look at them later.
As for the linearizing coil, the amount of turns will vary based on your antenna length and diameter, so what works for mine will not necessarily work for yours. I fine tuned mine by making the coil, and then adjusting the height of the antenna until it was very linear.
Winding a coil by hand is just like it sounds - you wind the wire around the coil form. It is not particularly difficult to do.
Posted: 1/4/2006 6:20:29 PM
alf
Thank you.
I didn't know you wound the coil "by hand" that way, I looks like a lot of work but quite easy.
I'll try it, then!
Posted: 1/4/2006 9:07:06 PM
Etherspiel
Hi Alf -
I recall that the RS Theremin site: www.oldtemecula.com
had some instructions on it somewhere for winding coils.
To figure out the resulting value of my coil, I used the online coil calculator that Maxies Pages used to link to, but that is no longer on the internet. I remember calculating the values based on coil diameter, wire diameter, antenna length and diameter. After building the coil, I intentionally made my antenna extra long, and then shortened it bit by bit to fine tune it to the coil.
For the capacitor values, I simply doubled them, which resulted in a nice usable range.
Hope that helps a bit...
Posted: 1/4/2006 9:11:23 PM
Travis
thank you very much
i cant wait to modify my Theremax.
-Travis
