Why not just stick a few windings at the "cold" end of the field coil? The windings will mostly just interact with those near it.
Might need a grounded foil shield between them to kill capacitive coupling. I thought of doing this a while back.
-- dewster
With sensing coils as a section on the main inductor would require 3 wire connection to the inductor, and sensing connection should be short to minimize the noise.
With on-board sense transformer it's possible to place the main inductor far enough from AFE board, and sinsing amplifier (part of analog multiplier) may be located millimeters from the transformer.
Capacitive coupling could be a concern - it may mix common mode signal (drive) to the sensing signal - shifting sensed phase.
But I believe if transformer coils are located in the same layer (dual spiral), then mutual capacitance should be low (less than 1 pF).
Since one end of sensing coil is connected to reference voltage point, and resistance of the coil is very low, it's hard to influence the voltage on other end of the coil via mutual capacitance.
The amount of energy transferred by inductance will be significantly bigger than one introduced by the capacitance.
