Posted: 6/15/2022 12:43:50 PM
D-Lev Kit : A Traditional Layout
Thinking about how to house the D-Lev kit in a more "traditional" EW type layout:
1. The pitch and volume boxes are arranged so the "business" ends are pointing out.
2. The top of the tiny tuner and the top of the control unit are aligned.
3. The blank area below the tuner could be used for auxiliary controls.
4. The I/O panel would be located on the front face.
5. The cabinet could be a simple closed box, as removing the control panel would provide sufficient internal access.
6. The overall internal width here is about 20".
7. The entire thing could optionally be tilted towards the player via a boom mike stand.
8. Considering foil & heatshrink covered PEX tubing, and UHF connectors for the rod antennas.
[EDIT] trying to round up parts for the build. After hours on the web ran across the On-Stage UM5006 (https://on-stage.com/products/view/12056/237108) which I ordered 4 of from muzeekworld for $9 each. Plan to take the rubber thing off the back and maybe stick it on the front, then mount the whole thing inside the case.
Posted: 6/15/2022 2:54:22 PM
bendra
You could fit it in a more compact width (assuming that is desirable) by standing the pitch and volume boxes on the short end, no?
Posted: 6/15/2022 3:49:51 PM
"You could fit it in a more compact width (assuming that is desirable) by standing the pitch and volume boxes on the short end, no?"  - bendra
True that.  But that would put your left hand kinda close to the volume coil (and field) when adjusting the knobs (something Roger noticed on his P3).  Adjusting the misc. controls under the tuner might similarly run afoul of the pitch coil field.
The overall width will be similar to an Etherwave, I think?  Does anyone know the width of the EW cabinet?  TIA!
Posted: 6/15/2022 7:06:38 PM
bendra
My hunch is to worry more about hand proximity to the banana jack rather than the coil itself. I could be wrong about that.
Posted: 6/15/2022 7:13:30 PM
"My hunch is to worry more about hand proximity to the banana jack rather than the coil itself. I could be wrong about that." - bendra
The whole end of the coil on the banana jack side is sensitive to capacitance.  You can sorta play the D-Lev this way with no antennas plugged in [VIDEO].
Posted: 6/15/2022 7:27:43 PM
bendra
Interesting, and important for cabinet design!
Posted: 6/15/2022 7:39:50 PM
RSchwim
18” x 5 1/2”
Posted: 6/16/2022 2:47:55 AM
"Interesting, and important for cabinet design!" - bendra
Yes, I should make a cabinet design document to help guide folks, there are lots of little gotchas, and lots of little things that might seem important but aren't really.
18” x 5 1/2”  - RSchwim
Thank you Rob!  The person you're helping may be yourself!
