Coil Embiggening
As I posted over on another thread, the kit has been on hiatus for over a year now due to some health issues, though they are hopefully largely past now. I'm reluctant to make more kits in their current form because incremental improvements could be made. I want to:
1. Increase the inductance of the coils, perhaps 4x.
2. Improve the AFE if possible.
3. integrate the coil, AFE, and plate antenna as a unit.
4. Switch to CAT5 interconnect for the AFEs.
5. Use 5V LCDs if possible.
6. Use PCB material for the control and tuner panels, as well as the logo plate.
7. Beef up the ESD protection.
8. Mount the dedicated mute LED on the control panel.
9. Rearrange the expansion port, possibly separating it into two.
10. Possibly reduce the encoder interconnect and handle them more in SW.
Right now I'm working on #1 thru #3. The goal of #1 is to lower the operating frequencies of both the pitch and volume fields, ideally to get both out of the AM broadcast band, and the lower frequencies would help ease timing demands on the oscillators. The LC operating frequency is unfortunately inversely proportional to the square root of the inductance, so e.g. shifting the resonant frequency down an octave requires a 4x increase in inductance. Previous coil experiments indicate that aspect ratios of 1 or larger are desirable from the standpoint of maximizing Q. Previous coil winding experience has me avoiding wire any finer than 34AWG. So these seemed like a good place to start. I wound two 8mH coils, one with 34AWG on a 60mm diameter 3D printed form, and another with 32AWG on a 70mm diameter form:
Above from left to right: Kit 1mH 38mm/30AWG, test 8mH 70mm/AWG32, test 8mH 60mm/34AWG, kit 2mH 38mm/32AWG.
In terms of winding, finer wire always presents more difficulty, though the smaller form diameter somewhat makes up for this. As usual, for both coil forms I set the 3D printing z-step to slightly more than the width of the wire, which really helps to guide the winding process. Obviously, finer wire requires a smaller z-step, which directly lengthens the printing time.
On the test jig the 60mm/34AWG Q measures around 158, whereas the 70mm/AWG32 Q measures around 198, so the larger coil is the clear winner here, and it has the highest Q that I've seen so far. I went ahead and designed and printed a plate mount for it:
Above: 70mm/AWG32 with plate mount.
The mount places the "hot" end of the coil 2/3 of the form diameter away from the potential plate, which from previous experiments should lower the resonance peak by less than 2%. The plan for the other end is a plug of some type to support the AFE. And this larger diameter form could likely benefit from an internal stiffening rib or two placed near the middle. Printing these elements in any quantity would likely benefit from a printer nozzle diameter increase from 0.4mm, perhaps 0.8?
The kit coils are 1mH for pitch and 2mH for volume. My reasoning here was that when folks placed their hand on the volume loop, the lowered volume field frequency then couldn't overlap and potentially disrupt the pitch field. With the use of an insulated volume plate this is much less likely, so I'm strongly considering flipping this, i.e. using 8mH for pitch and 4mH for volume, which would at least get the pitch field out of the AM band.
Now to print a 4mH 70mm/AWG30 volume coil. It's rather tedious work, but I really don't mind putting this extra effort into the coils, they're the beating heart of the Theremin after all.
[EDIT] Just wound the 4mH coil:
Above: 4mH coil (left) 8mH coil (right).
The 4mH coil Q is 213, which is a new record for all my coil winding!
