Posted: 2/25/2020 8:06:44 PM
zevot
Hello Thierry, I followed the Keystones video and build this circuit but havent get sound from the antenna. I used J113 instead of 2N5484 and all the other components are identical. I got some strange radio like sound from amplifier but the antenna is not function at all.
Btw, is your C13 1.5nf?
Posted: 3/18/2020 10:21:42 PM
Imberlimerence
Hi all! I am using this design for my senior project and have unfortunately hit a block. I am using a guitar amp as the audio out and an currently only getting static. If I unground the audio jack connected to the guitar amp, I can get a slight pitch variation in the feedback if I pinch the antenna. I don't know what I'm doing wrong and have re built the circuit three times on a breadboard. Any help would be much appreciated as I need to fix this to graduate!
Posted: 3/18/2020 11:22:27 PM
Tune your Analog AM Radio to around 900 khz and you will find two blank spots in the static on the AM band if both oscillators are working. This is 2 x 450 khz or whatever it is.  If you find the two blank spots tune to overlap them. This is fun stuff. Thierry a genius but I got the edge. I have a pdf toner transfer print out for this circuit I can share if you know what that is.
Your coils are probably 10% so the oscillators could be out of tuning reach of each other, you might need to add a few PF's to one side. Also have a length of wire for the antenna mounted. This should drive your amplifier for the experiment.
In my graphic below I added a spot for a LDR volume control.
There is a lot to learn from this design, like why I avoid using FET's.
www.Hwy79.com
70 mm x 100 mm
Posted: 3/20/2020 7:49:39 PM
tinkeringdude
The beauty of the layout almost rivals that of the bird.
(no, I don't like the sight of P-to-P tube amp circuits, either )
