Need help with strange pitch problem - Etherwave Standard
Posted: 12/21/2015 11:30:06 PM
ufew42
Hi everyone,
All of a sudden I'm having an issue with my Etherwave Standard. Sorry in advance for my lack of technical terminology.. despite playing for years I'm still ignorant of how to explain this stuff.
In the lower range, pitch seems normal. When my hand gets nearer to the pitch antenna, the pitch suddenly becomes "thin" and very high pitched, similar to the typical sound that occurs when one touches the antenna. As I draw my hand back towards my body this "squeal" persists, until it suddenly jumps to a lower (normal) pitch.
Here's a video I made of this problem
Any help is very much appreciated. I haven't yet tried fiddling with internal tuning since I'm not sure if that's the issue.
Thank you!
-Megg
Posted: 12/22/2015 5:19:32 PM
Hello Megg,
That was a great video for diagnosing your issue, how could someone describe that in words. My best guess would be first to check how good the grounding is of the theremin. A theremin needs to have three prongs that plug into the wall, if not the amplifier you are using needs to have a three-prong plug into the wall receptacle. In my research I have found earth ground has more benefits than just completing the player capacitance loop, what ever that is. My impression is your pitch oscillators are locking on to one another, why it holds even after pulling away. "Proper grounding may alleviate some of the built up oscillator energy and tension". <= I just created that thought.
Posted: 12/22/2015 7:56:12 PM
mpampouras
Hm seems like it's gone totally out of tune. Are you able to get zero beat?
I think if you are not into technical stuff you need to send it to someone qualified, to be sure.
