Connecting a Theremini to a PC
Posted: 2/4/2016 10:25:26 PM
xtheremin8
the manual says:
USB CONNECTOR
Connect your mixer to a computer using a standard USB cable. This enables a stereo signal to be sent to and from your mixer and computer. The signal sent from the mixer to the computer is the same as the main bus. The audio returning from the computer into the mixer appears directly in the main and/or control room bus (depending on USB/2TR to MAIN and PHONES/CTRL RM buttons).
NOTE: The mixer cannot be bus-powered via USB! Always use the included power adaptor to supply power to the mixer.
i had a behringer mixer with built in effects for some time, and it was a noise hell. because of that fancy built in fx. now i'm a bit more carefull with all-included devices. some reviews of those xenyx mixers stated noise issues over usb. but  people hear things differently.... that power socket looks quite unique on those units. behringerspezial.
somehow a bit chewed up but still true: buy equipement from a trustworthy shop in your town: you can talk stuff, and even try them out.
edit: i think, those bespoken xenyx units are a so called no brainer for a start into mixing/recording? sometimes routing signals back and forth can be a bit confusing (or a earpiercing experience) but that's a part of it.
Posted: 2/5/2016 12:05:11 AM
"the manual says: "  - xtheremin8
Ha!  Yeah, sorry, I should have looked at the manual before passing along FUD.  That reviewer probably didn't know to press one of those buttons.  Strangely there is no data in the manual regarding the A/D D/A sample bit depth, so I would assume 16?  For recording I'd prefer 24 bits.  It says the sample rate is 48kHz, so I wonder if it can even do 44.1kHz?  When is a manual not a manual...
Posted: 2/5/2016 6:21:21 PM
cosmic kid
We have amazing audio stores in Montreal so defo going to check the Xenyx out first hand. It's always new things I face such as this topic that trigger me to look for an immediate result but then realize it's actually a longer learning process and journey of discovery.
Thanks for all the responses guys, I'll keep you up to date on how the mixer works out.
