Breaking the Vibrato Barrier
Posted: 12/16/2019 4:58:31 PM
rupertchappelle
I doubt that anyone has noticed that I play possibly the fastest vibrato of any other thereminist. Not due to any particular skill, but rather simple physics.
The open hand is much like the spinning ice skater with arms extended - more momentum, less speed, my hand is cupped, much like the spinning ice skater with arms drawn inward - less momentum, more speed.
Extended fingers and open hands limit the speed of your vibrato - just physics.
Not enough for me, though, so I had started making a fist to increase the vibrato speed even more, but only slightly faster. the problem is that the nervous system goes only so fast, so I met with another barrier, the Vibrato Barrier.
Solution is very simple, as one makes a fist with the pitch hand, tighten all the muscles in the pitch arm and wrist until the muscles go into self oscillation - a trembling and shivering effect. Since the range of motion is very limited this technique is most effective on the higher octane ranges. As one goes lower in pitch the effect lessens to a subtle growl added to the lower notes and for bass it is pointless.
My favorite cliche with this technique is to start with a very slow vibrato and ramp it up to ultra fast vibrato.
Like all vibrato, this technique should be used sparingly. No pain issues or joint issues since little actual motion is involved. No carpal tunnel issues hopefully.
This technique should be attempted only by the best professional precision thereminsts who are capable of playing with or without regular vibrato.
Like Charlie Draper.
Posted: 12/16/2019 9:16:47 PM
pitts8rh
I like this method too except that I start feeling pain in my elbow if I do it too much.  I'm trying to practice a more relaxed wrist wobble but the tense method that you describe seems to give the best control.
Posted: 12/17/2019 6:13:19 PM
DreadVox
It's an approach that works, and I think with a very fast vibrato when used sparingly enough, the toll on musculature will not be much, just remember to relax as if holding butterfly wings while playing most of the time. Most natural vibrato in human voice and musical instruments is not terribly fast, usually around 6-7 Hz, which is easy enough to achieve with relaxed underarm and/or wrist movements.
Posted: 1/3/2020 6:32:59 PM
rupertchappelle
I only use it as an accent and generally spend no more than 10 seconds total actually doing it in a piece, but not always.
