Posted: 9/4/2021 7:43:10 PM
RoyP
dewster, if this was FB, I'd give post #136 a
Posted: 9/4/2021 7:47:38 PM
ContraDude
Congrats! Why did it play in the beginning?
That’s a very good question! I can not identify anything to point to a reason. The instrument was never moved, nothing touched it, one day it worked, the next day it did not.
After Eric worked on it yesterday, it played at his place. We packed it up, very gently, and when I arrived home, it played for about a minute then stopped.
After a considerable amount of time, I noticed the pattern shown in the first video - slight insertion of the volume antenna produced a sound and seemed to work; anything else and suddenly no audio. However, I could replicate it and that’s when I made the video.
First thing this morning, I could still replicate the situation and Eric invited me over. Eventually, we found the solution (at least we hope so). Given the odd behaviors already observed, I just hope it remains fixed.
Posted: 9/4/2021 8:17:21 PM
DOMINIK
"Why did it play in the beginning?"  - DOMINIKThere was sufficient capacitance between the antenna and the connector to sustain good voltage swing?
Sounds reasonable. Luckily there has been enough clearance with the variable inductor. Otherwise no problem: just saw off a little piece from the antenna.. gently..
Posted: 9/8/2021 12:35:10 AM
Peragere
Just contacted my seller "DJ Store" in Australia and they have given me a "subject to change" delivery estimate of October. I don't mind the wait. One thing I did organise with them was an extended warranty, so now I am covered for anything going wrong for 3 years. That ought to sort out any demons.
Posted: 9/19/2021 1:36:05 PM
nocomp
hi folks,
i had no issue with mine, and lately, after have calibrate the volume in modern mode, no more sound in traditional mode....
i had some issue with volume and playing with antenna was sorting it out, or after theremin powered on for a long time, no more sound, reboot was doing the job, but not anymore.
any way to fix that? cant even find a reset procedure, that s weird, is there any?
thxx for your time
Posted: 9/19/2021 3:31:28 PM
bendra
hi folks,i had no issue with mine, and lately, after have calibrate the volume in modern mode, no more sound in traditional mode.... i had some issue with volume and playing with antenna was sorting it out, or after theremin powered on for a long time, no more sound, reboot was doing the job, but not anymore.any way to fix that? cant even find a reset procedure, that s weird, is there any?thxx for your time
This may well be your problem
Posted: 9/19/2021 4:18:10 PM
nocomp
dont think it s the same issue, mine was working fine till i do volume calibration in modern mode, now classic mode volume is gone. i can hear a thin sound whi the speaker, like a leak of sound volume, no clear sound.
it works perfectly in modern mode, if the volume antenna had a connectivity issue, it wouls also be useless in modern mode  no?
Posted: 9/19/2021 4:28:55 PM
nocomp
interesting, i ve tuned the volume using the tool , got a sound when doing 2 round ccw but it s un playable, when i turn the volume antenna button to the right, i get no sound, should be the opposite, i ve reset the coil to where it was. weird
Posted: 9/19/2021 5:07:30 PM
nocomp
r tightness.[EDIT] So a proposed volume loop "tuning" procedure sans equipment:0. Ensure volume loop connectivity (sand the end face and locking studs if necessary).1. Put the Claravox in "Traditional" mode.2. Set the "Volume Antenna" knob to 12 noon (straight up).3. Adjust the volume coil slug for maximum volume with your hand away from the volume loop (kinda hard to do while adjusting the slug!).4. Wiggle the "Volume Antenna" knob to ensure maximum volume is around 12 noon, if not repeat step 3 & 4 until it is.
thxxx a lot,
did that works like a charm
Posted: 9/19/2021 5:29:55 PM
ContraDude
thxxx a lot,did that works like a charm
Fantastic!! Dewster is great - he posted the instructions. My video showed the same thing. What was your serial number?
