What's Your Theremin Going To Be For Halloween?
Posted: 10/24/2008 12:44:36 PM
omhoge
Cliché as it may be, this can be a fun time for aether players.
So is your theremin making any special appearances for Halloween?
Will it wear a little cape?
Will it be set up at your party, so when folks pass it, it sings?
Will it be playing dramatic or melancholy classics late at night?
Will it be hiding with you behind the pumpkin to scare trick-or-treaters?
Whatever you're up to, I hope everyone has fantastic late Autumn holidays!
Posted: 10/24/2008 1:38:01 PM
Here's a handy, portable faux-theremin if you don't want to take your RCA Victor out trick-or-treating. You might even already own the necessary equipment...
http://www.youtube.com/watch?v=ZaOj99IlzDc
Posted: 10/30/2008 10:56:58 AM
Gordon, you might influence the linearity and the pitch range by modifying the acoustic environment, i.e. by pulling a sock over one of the walkie-talkies or by wrapping slightly it into tissue paper... ;-)
Posted: 10/31/2008 10:47:03 AM
Thomas Grillo
Hi Thierry, I've also observed this affect on linearity when putting cable sleeving on my pitch rod.
Posted: 10/31/2008 4:14:24 PM
kkissinger
The last couple of years the Halloween weather has been cold.
Today is pretty warm and this evening should be comfortable so I think I'll set up in front of the house with my Etherwave Standard, a loop pedal, and a couple of speakers. I can make quite a few eerie sounds. I'll set up so that trick-or-treaters can try out the theremin, too.
Should be fun.
