Doug Forbes Theremin tips
Posted: 3/30/2005 9:07:35 AM
capzloc
Hey all-
I have been looking into building a tube theremin and the Doug Forbes model looks like the simplest. I have never done a tube project before and I was wondering if anyone out there has successfully completed this or any other tube theremin in case I run into problems.
Also, I figured out that the coil Doug was referring to was the P-C70-OSC. Does anybody have specs on this coil? I prefer to buy parts from local stores than online and I want to know what I am looking for.
Thanks!
Matt
Posted: 5/2/2005 12:10:56 PM
Etherdave
I have tried to build the Forbes but so far all I can make work is the filament circuit. My transformer, Hammond #269JX, produces more volts than it's rated for, and this has screwed up the whole B+ circuit (I've blown more diodes than you can count). The oscillator circuits won't generate tones, otherwise it should work. My local expert informs me the OSC-70s are good and the appropriate choice for this application. I'm going to clear out all the components and start over with the reference oscillators. If I can get these to work the rest will follow.
Posted: 2/2/2006 2:42:14 AM
valveodour
Hello!
I get that coil 70-OSC from Antique el. suply.Now, from the coil schematic:
coil schematic (http://www.pasmaters.com/slike/70osc.jpg)
you can see there is a one turns on coil-primary and two on secondary.Wich turns I have to use in this theremine project?Secondary I guess.In that case,is the primary turns stand open(not conected)?
Thanks
Posted: 3/15/2006 12:26:29 AM
Etherdave
The second, center diagram in the instruction sheet that comes with the coils shows the proper wiring. Secondary windings only are used.
Posted: 3/15/2006 10:25:20 AM
valveodour
Thank you
Posted: 4/11/2006 10:55:39 PM
Etherdave
Oh, by the way, those oscillator coils are available through Antique Electronics Supply out of Tempe, Arizona. The code we keep quoting is the order number.
