components
Posted: 9/30/2005 4:51:41 PM
victor
In the Theramax 9505 kit, is the 1kuh choke coil the same as a 1k ohm resistor?
Posted: 9/30/2005 8:03:53 PM
user
I'm not familiar with the schematic, but in general, they are entirely different components with different parts to play in a circuit.
You won't be able to subsitute one for the other. Are you missing parts from a kit?
Posted: 9/30/2005 11:19:44 PM
kkissinger
The choke is not interchangeable with a resistor. However, the supplied choke LOOKS the same as a resister -- fortunately the choke is slightly larger than the supplied resisters, so you should be able to pick it out from the other parts.
Posted: 10/2/2005 7:03:00 PM
user
Also if you put an ohm-meter on it you should get 1000 ohms for the resistor and very little resistance for the choke.
