Etherwave Connection/Amp Help
Posted: 8/3/2007 8:32:08 AM
Dork Knight
Hello All,
I’ve been considering purchasing the Moog Etherwave Standard but I have a few concerns about connections and amplifiers, I was wonder if anyone would be able to tell me if the following would work;
Etherwave to;
http://www.turnkey.co.uk/web/productAction.do?dispatch=showProduct&SKU=MOOG-ETHERSTD&context=WEB
Phono to 1/4” Stereo Adaptor to;
http://www.maplin.co.uk/Module.aspx?C=SEO&U=SM&ModuleNo=991
RCA/Phono to 3.5mm Jack to;
http://www.maplin.co.uk/Module.aspx?ModuleNo=220194&criteria=rca%20to%203.5mm&doy=3m8
PA2V2 Headphone Amp;
http://www.electric-avenues.com/audio8.html
Microphone Stand;
http://www.turnkey.co.uk/web/productAction.do?dispatch=showProduct&SKU=QL-A399&context=WEB
Any advice on this setup or similar setups would be greatly appreciated.
Many Thanks,
Jason
Posted: 8/3/2007 9:28:02 AM
omhoge
Welcome to TW!
You'll only have a 1/4" mono line level audio out.
I'd avoid use of stereo cables with any Moog theremin, they do not connect fully and in the EWPro causes the mute switch to leak.
You should be able to use an adapter on the 1/4" mono cable to connect to most any amp or powered speaker. When I first got mine I used a hand-me-down set of powered computer speakers.
I've gradually been upgrading the amp and now use a Roland 12".
For other amp options try the search page too, there's been a lot of thoughts posted in the past about folks' choices.
For headphone amps I swear by headroom and use one attached to the side of my theremin for the pitch preview feed.
http://www.headphone.com/products/headphone-amps/the-mobile-line/
hth and keep us posted on your theremin adventures!
Posted: 8/3/2007 11:03:13 AM
Alexander
The Fender 25b (http://www.soundexchange2.com/index.asp?PageAction=VIEWPROD&ProdID=597) bass practice amp has always been my favourite Theremin amp... essentially you'll want something that sounds nice that you can listen to with clarity and doesn't colour the sound too much. Headphones tend to be a bit claustrophobic and sound all wrong, to me at least.
Posted: 8/4/2007 4:52:14 AM
buddy_craigg
Alex,
have you been listen to me play again?
Posted: 8/4/2007 6:33:52 AM
Dork Knight
Thank you for the information and welcoming me to the forum.
I was considering using the PA2V2 as it’s currently on loan to a friend as I have no use for it, so I thought I would put it to good use.
I’ve not tried any of Tylls Headphone Amplifiers but I do have the following which I’ll have to try with the Etherwave;
Corda PreHead MkII SE;
http://www.ttvj.com/index.php?main_page=product_info&cPath=&products_id=451
NAIM HEADLINE 2;
http://www.musicdirect.com/products/detail.asp?sku=ANAIMHL2WISUPPLY
RSA Emmeline "The Tomahawk”;
http://www.raysamuelsaudio.com/new.html#tomahawk
I’m planning on purchasing the Etherwave later this month so no doubt I’ll be floating around the forum.
Thank You,
Jason
