"Fred, based on your experiences I think all designers should consider the main form of SNR in Theremins as the ratio of antenna voltage swing to environmental interferers." - Dewster
I think that any "rule of thimb" for theremins should be questioned - Yes, my expierience leads me to think SNR as a function of antenna voltage is to be highly regarded, but there are many other factors that MIGHT be just as important - The "trouble" with theremin designs is the numerous subtle things to think about..
An example of this is demonstrated by some experiments I did on deliberately modulating the VFO using voltage control (I was feeding temperature compensating, equalization, tuning and audio modulation to a summing amp,and the output of this amp was varying the tank capacitance).
I got a load of mains frequency FM, and assumed this was antenna interference - spent ages trying to track this down at the antenna end until I discovered a floating input to my summing amp - I had checked this amp before connecting it to the VFO modulation input, so was sure it wasnt the source of the problem - but this input had gone to a preset's wiper (to set DC bias) and this had gone OC.
There are loads of potential inputs for LF (and other) modulation - Antenna, coils, CV's from tuning circuits, PSU.. All one needs is enough to modulate an oscillator by a few Hz for any of these to become a problem.
"I haven't done a thorough search yet, but a part like this would likely work better:http://www.onsemi.com/pub_link/Collateral/ESD7181MU-D.PDF"
Yes, that part looks almost ideal. A unidirectional version with its K connected to the Drain and its A connected to the gate would prevent G from going +Ve WRT D, and limit the gates -Ve to safe levels.. But IMO one still needs an antenna-side discharger of some kind to limit transients to <100V by the time they reach this secondary protection.
Added ->
Working a lot with PLL's had an advantage that modulation is easy to observe - A simple 4046 without any divisor allows one to observe the demodulated signals after the filter (VCO CV in)
Added -> [pure hypothesis] Re PLL's and amplification vs heterodyning "amplification" ;-)
Just thinking about PLL's got me thinking about another way to derive CV from a "front end" - If one has a reference and variable oscillator each driving a PLL, and one took the error voltages from both into a differential amplifier, you should, all thing being equal, get a voltage proportional to the frequency difference between the two oscillators..
This is a bit like heterodyning in a way - deducting the variable frequency from the higher fixed one - gain would be determined by the VCO sensitivities and/or the differential amplifiers gain.. Viewed this way, I can see a reason to think of heterodyning as "amplification" - But the difference is that with heterodyning there is actually no way to "amplify" or "attenuate" the resultant difference frequency, because this is simply the difference...
On the other hand, perhaps if one did derive a difference voltage using PLL's and a differential amplifier, and this had sufficient gain from whatever means, one could get extremely low latency (the error filter would have extremely small TC) and could use a fast ADC to get digital data from this....
Added ->
Thinking about things in the above terms - One would only "need" a single oscillator (VFO) and PLL (demodulator) , and one could deduct a reference voltage from the error output to get a voltage proportional to changing capacitance. This is a closer analogy to the direct-digital scheme perhaps - You would need to amplify the difference (something you cannot do if dealing with a period, as you are with direct-digital)), or accumulate the difference additively over a period of time, to get the required resolution.. The differential method using two oscillators has the advantage that if these oscillators are similar, errors will be reduced on the difference output, but some form of amplification will still be needed. Whatever way one does things though, standard heterodyning always comes up as the winner AFAICS.
