TW needs a little stimulation
In my Switched on Clara sound byte I turn on my second EWS Harmonic Exciter PCB board about halfway through. I will be getting 10 of these 4-Layer boards made this week. It has been 15 years in the making, dewster might be the only one to out do my own perseverance. My design will give you flute, Clara, violin or cello, in other words a broader palette of "natural" organic sounds.
This is not for beginners as the soldering is critical. Valery S will receive the two boards at no cost along with all the Mouser parts and a few extra things. I need him to build with success as his homeland is Saint Petersburg, Russia which is also that of my mentor Lev Sergeyevich Termen, whose birthday we celebrate on Monday 8/15. There will be five other PCB sets available to anyone at no cost that can prove they have building skills.
For everyone the red wire seen through the volume loop below is rated at 40,000v and completely prevents static discharge damage to your theremin, softens the volume response near the loop, gives a nice shading window and lets you grab the loop with a smooth transition. The volume circuit adapts nicely and does not need re-tuning. Static discharge off your fingertip is never more than 10,000 volts. ebay
The 3" x 3" green board at the top of the photo is there for simulation of the actual board.
Edit: 10 pcs of the 4-layer PCB have been ordered, should have by Sept 1, it is fascinating how many little tweaks came about in the last few weeks. Flute, Clara, Violin are straight forward. Cello we will have to wait and see how realistic.
![](http://www.oldtemecula.com/theremin/ews-buffer-exciter/images/breakout-mounted-vertical.jpg)
