midi theremin ala dimension beam
Posted: 4/9/2006 1:57:37 PM
transientlx
i need to find something that is a rock solid x-y-z midi controller simillar to the dimension beam http://www.harmony-central.com/Events/WNAMM98/Roland/Dimension-Beam.html . i definitely do not want to buy and roland gear and i am not very good at essembling electronics...
http://www.jaycar.com.au/productView.asp?ID=KC5410
any ideas would be hugely appreciated.
Posted: 4/21/2006 9:44:10 PM
knockman
hi transientlx,
i built that midi theremin but i'd guess it's not really what you need, it works as a gestural controller ok, but is rather limited in its scope unless you are prepared to make some significant modifications.
see this thread for more http://www.thereminworld.com/forum.asp?cmd=p&T=1047&F=715
in fact i was just talking with a guy who designs and builds hardware-software solutions about midi theremin as there seems to be a lack of decent solutions. maybe inthe future something more will come, but i'd say the jaycar kit as it stands is a fun project to build and capable of wild (read unpredictable) results - which i quite like, but when i want to play musicaly i use my kees enkelaar.
hope this helps, for what you need perhaps look at a Paia Theremax (http://www.paia.com/theremax.htm) combined with a Paia MIDI Brain (http://www.paia.com/midibrn.htm), or doepfer (http://www.doepfer.de/home_e.htm) make modules for building all manner of things, very good, solid construction. you can find a theremin antennae module which outputs cv, or a light sensitive one and so on - you'd need one per parameter, if you connect them to their cv to midi module you'd have yourself a controller that could be used with a range of midi gear, you should read their pdf manuals to see if that's viable for what you wish to do though. if i were doing this sort of thing live, i'd go with doefper just for the construction - my jaycar midi theremin wouldn't stand up to it i fear.
regards
Posted: 4/23/2006 10:51:50 AM
rupert
try eowave.com, i thought there other gear would be of interest to you after checking out the persephone.
Posted: 4/23/2006 6:40:18 PM
knockman
thank for that link rupert, i hadn't come across eowave before.
i just checked out some of your great videos too - great stuff, i've bookmarked the page so i can see them all.
regards
