minimum theremin troubles...please help
Posted: 11/23/2008 2:00:27 PM
BlackEdition
so i successfully constructed one of the minimum theremin based on art harrison's schematic. however, i am running into a bit of a problem. when plugged in to an amp, the theremin is very quiet. i have to turn the amp to pretty much maximum volume for the theremin to be audible. is there some sort of pre-amp circuit that anyone knows of that i could boost the volume with?
thanks!
Posted: 11/23/2008 4:23:48 PM
Following Arts circuit description the output amplitude varies from 120mV (at 1800 Hz) to 2V (at 80Hz). Even the weakest value is still enough to overdrive a normal keyboard or guitar amp.
So the conclusion would rather be that there is a fault in your circuit. You should take an oscilloscope and check the voltage levels at the output of the 2 oscillator buffer stages (Pins 6 of U1 and U2) where you should find a 5Vpp rectangle signal. From there you should go further to the mixer output (Pin 12 of U1), then behind the low pass filter (Pins 9 and 11 of U1), behind the output amplifier stage (Pins 8 and 10 of U1) where the signal should be 6 to 10 times stronger than at the input. Finally check the output divider R9/R10 where you should not encounter a considerable loss.
Posted: 11/24/2008 7:32:47 AM
Sorry that I took a little more than 2 hours to answer...
Posted: 11/24/2008 8:05:05 AM
BlackEdition
no need to apologize! thanks very much for the help. i will try to see if i can't get my hands on an oscilliscope for a bit...
Posted: 11/24/2008 8:32:02 AM
I bought a very cheap pocket-oscilloscope-multimeter some months ago, the UT81B by Uni-Trend from a Chinese seller on ebay. For me it was still cheaper in the time when the US Dollar - Euro conversion rate was still more interesting for Europeans.
Naturally this is not a high precision lab device but it is more than enough for first aid on audio devices and theremins. A simple waveform/amplitude/frequency check is possible on the 160x160px display and that's even enough precise for tuning a Moog Etherwave Standard.
