Posted: 2/4/2023 8:36:42 AM
Martel
I made a version of this circuit with varicaps, and an effective tone adjustment with a variable resistor. If anyone is curious, I can provide a diagram. .
Posted: 2/4/2023 1:47:53 PM
Martel, are you properly grounding it?  Could you perhaps have a ground loop (multiple grounds can cause this)?  If you post an MP3 sample of the low note problem I might be able to help.  Lots of mains hum in the typical room environment.
Posted: 2/4/2023 1:56:41 PM
Martel
dewster - These theremins are small in size, even sometimes without a nut to mount on the stand. That's why I don't ground. And I don’t even have grounding in my apartment. (neither good nor bad. Only zero and phase are brought into the apartment).
But I will try to record the sound of this "triple" one of these days.
Posted: 2/5/2023 11:02:21 AM
Martel, grounding is a very basic aspect of Theremin operation.  I've read you can stand on a metal plate under the Theremin, or throw enough wire on the floor (with either connected electrically to the Theremin) and get good results.  The audio connection to amplification may be enough too.
Posted: 2/8/2023 6:11:51 AM
Martel
dewster - I will try to record the sound of this "triple" one of these days.
Here is a recording of the defective sounding of theremins in my apartment, where there is no grounding (on the third floor and only zero and 220 volts are brought into the apartment).
Theremin is powered by a 9 volt battery. the recording goes to the computer, which means that there is a binding by "mass" (this is not earth).
I tried to "ground" on the heating battery and on the metal box - without result.
This makes me very nervous and upset.
But here's what else you need to try - to record the sound of the theremin without connection to the electricity network.
Powered by a separate battery, and recorded on a recorder-voice recorder. To exclude the power supply. Which is probably polluted by impulse devices and does not have not only quality land, but it does not have it at all.
audio - https://cloud.mail.ru/public/xDNj/vLkxJXyi4
Posted: 2/8/2023 7:36:59 PM
"(How to upload files here? Is it completely impossible without an intermediary file hosting service?)" - Martel
I believe you can only upload pictures here (which is nice).
I listened to your file and looked at the spectra in Audacity.  Around 25 seconds in there is a fairly steady pitch area of 391Hz or so, and it is quite noisy sounding.  If you have a scope you should look at the output of each oscillator, as well as the mixed result, for any instabilities.
