Idea: LTSpice raw file audio player
Posted: 3/30/2017 5:43:02 AM
Buggins
Hello,
I have a nice idea.
Write player app which takes LTSpice output and allows audio playback for some signal.
Especially it could be useful for analog theremin designers.
Modify schematics. Run simulation. Press reload in player app. Press play. Repeat.
Another use case: prepare C(ant) changes file and feed it to LTSpice to sweep antenna capacity. Use program to hear if schematic produces enough linear response.
Posted: 3/30/2017 12:37:07 PM
You can generate audio files in LTSpice:
  http://www.linear.com/solutions/6087
IIRC the amplitude must be restricted to 1V, which you can do with a resistive divider if necessary.
Posted: 3/30/2017 12:55:48 PM
Buggins
"You can generate audio files in LTSpice:   http://www.linear.com/solutions/6087 IIRC the amplitude must be restricted to 1V, which you can do with a resistive divider if necessary."
 Wow. Did not know about this feature.
Thank you!
