Theremax pitch preview?
Posted: 12/8/2007 2:24:50 PM
Alan_in_CA
Can someone help me here? The PAiA web site shows a pitch preview/aux. input modification at
http://paia.com/ProdArticles/therefaq.htm#therauxm
with a link to their headphone amp:
http://paia.com/proddetail.asp?prod=9605K
but it's not at all clear to me. I suppose the two are somehow additive.
Posted: 12/8/2007 2:39:15 PM
kkissinger
The pitch preview produces a line level signal and it needs some amplification to drive an earbud (or headphone).
I just use the little $14 mini amplifier from Radio Shack as a pitch preview amp:
http://www.radioshack.com/product/index.jsp?productId=2062620&cp=&pg=9&searchSort=TRUE&sr=1&retainProdsInSession=1&y=8&origkw=speaker&s=A-StorePrice-RSK&kw=speaker&x=14&parentPage=search
Posted: 12/8/2007 2:54:21 PM
Alan_in_CA
But how? How does this connect to the modification shown at the PAiA web site, or does it?
Posted: 12/8/2007 8:21:04 PM
kkissinger
Alan,
Since I don't use the "Mute" plug on my Theremax, I connected the pitch preview's output to the tip of the Mute jack. I use a 1/4" to 1/8" cable to connect between the Theremax and the mini amplifier.
-- Kevin
Posted: 12/8/2007 10:26:29 PM
Alan_in_CA
I think I see. Thanks.
Posted: 12/8/2007 10:27:27 PM
teslatheremin
Alan,
K.Kissinger uses the same Radio Shack personal amp that I use as part of my pitch preview circuit. The personal amp comes with a speaker, volume control and a earphone out jack.
I removed the amps circuit board from the case, clipped the speaker off and installed the board inside my T-Max case and the earphone jack to the T-Max front panel.
The desoldering and soldering assembly of the PAiA pitch modification is easy. If you built the T-Max, you can handle this.
To see this mod in a bad photo go to the pictures at http://www.myspace.com/unclenaguma .
Good Luck!
teslatheremin
Posted: 12/8/2007 10:30:03 PM
Alan_in_CA
A picture is worth a thousand words! But I have another question for you Tmax builders: What about that switch (Snew) in the schematic on the PAiA web site? Why have it open? Why close it?
Posted: 12/8/2007 10:33:08 PM
Alan_in_CA
naguma'at'myspace.com. Replace 'at' with the @ sign
doesn't seem to work. spelling error, perhaps?
Posted: 12/8/2007 10:35:02 PM
Alan_in_CA
Oho! It seems the firewall I am working behind at the moment doesn't allow me to access myspace.com. I will have to wait until I get home tomorrow evening.
Posted: 12/8/2007 10:41:07 PM
teslatheremin
Alan,
Try this one, silly me!
teslatheremin
